First post, by Wheezle
Hi. I'm trying to run conquests of the longbow on windows XP. I downloaded the audblast.drv to get digital sound, and followed instructions to stop the looping, which works ok. But the sound in the game gets jerky. The music pauses at points for like half a second then catches up (which sounds irritating). Also with some longer digital sounds (such as the singing when you enter the abbey) the sound cuts out before it finishes. This may be partially due to the aforementioned sound pausing.
I have found that if I set the cpu priority for the program to realtime, the pausing stops but my pointer does not move smoothly, and the cutting out still happens (but the sound does seem to last a little longer).
any suggestions? it still happens if I disable digital sound.
specs: Pentium 4 2.0 GHz, 768MB DDR RAM, NVIDIA geforce 4 ti 4200, soundmax integrated digital audio sound card (onboard)
Reply 2 of 8, by Wheezle
hmm that didn't seem to do anything 🙁
oh, actually if I run it without VDMS, the digital sound works fine, but no music.
Reply 4 of 8, by Guest
I don't know if this has been discussed before, but since I saw it as an issue on the compatibility area, I'll go ahead and post […]
I don't know if this has been discussed before, but since I saw it as an issue on the compatibility area, I'll go ahead and post it anyway.....
I was messing around with the launcher and it's settings and found a way to get rid of that nerve breaking audio loop on VGA Sierra games.....
Using the launcher, create the VDM shortcut and use the following custom configuration :
On Sound Blaster use IRQ 5
But on the DOS Environment type in the following on the AUTOEXEC.BAT area
SET BLASTER=A220 I7 D1 H5 T6
You might need to download the latest AUDBLAST.DRV that were released.....
This did the trick on Conquest of the Longbow & Dagger Of Amon Ra..... Haven't tried it on others.....
I'll be messing around with KQ5 next... let's see if there's a miracle on the making
Reply 8 of 8, by Wheezle
Yeah, i've always been able to do it without sound effects. That's not really the point 😜
