First post, by the-beast
Hi, does anyone know where you can get a PDF copy of the manual for a Elonex PC-425X Manual?
Thanks
Thanks
Or even just the jumper settings for the daughter board so I can upgrade the CPU to a DX/2 66. Thanks
hey - necro thread but i've got a dx2 66 working okay in my elonex pc-433/vl. managed to work out a few of the jumpers.
also came across an old manual for the mr bios settings - in case that helps anyone: https://www.esupport.com/techsupport/docs/mrb33x.zip
the-beast wrote on 2018-09-05, 18:51:Hi, does anyone know where you can get a PDF copy of the manual for a Elonex PC-425X Manual?
Thanks
If you have the Elonex PC-425X , could you extract bios rom dump and take a picture of the motherboard front and back and then upload?
I have the bios , is from the PCem rom collection. Inside are 3 roms, the full one and then just the board bios and the video bios as seperates.
You want the full one if flashing for actual use on the board.
Horun wrote on 2022-06-17, 00:03:I have the bios , is from the PCem rom collection. Inside are 3 roms, the full one and then just the board bios and the video bios as seperates.
this is for unknown acer310
Yes. Elonex did not make their own motherboards, they were OEM'd by various others AFAIK. The Mr BIOS file is referred to by otana above and do not think PCem just toss files into their BIOS compilation.
Did you burn it ? Did it work ? Some other links suggest Viglen oem'd some of their early boards to Elonex too. If the chipset on yours is ALI then it could be Acer oem... sorry is all I know ;p
A minor update: Found a memory and cpu update odd "doc" and created a readable PDF, it shows some info about the boards Elonex used.
Also found a Y2K doc which lists the boards used by Elonex...
I do not think those listed as "Elonex" in the docs were made by them because another website mentions they wanted to build a manufacture plant late 1990's but never did,
which means all their early boards are OEM from some other manufacture, the later boards are OEM/retail from other well known manufactures.
Will post it to Vogons Driver Library (Under manuals) too
Horun wrote on 2022-07-11, 01:52:Yes. Elonex did not make their own motherboards, they were OEM'd by various others AFAIK. The Mr BIOS file is referred to by otana above and do not think PCem just toss files into their BIOS compilation.
There is no official PCem BIOS compilation, all the compilations found around the Internet are third party, and for the Elonex PC-425X, they have, unfortunately used the wrong ROM altogether. Yes, the real Elonex also has a MR BIOS, but a Symphony chipset (most likely the 491 - PCem identifies it as 461 but Tiseno and I have both independently reverse engineered the actual 461 using multiple BIOS'es confirmed to be from that chipset, and the registers do not match at all), not ACER (ie. ALi) chipset (which?) which the BIOS in the compilation is for. I'm still on the lookout for the proper BIOS, but not even knowing what chipset the machine actually uses, is making it even more difficult.
Edit: Even the Trident video BIOS is wrong - it's a PCI video BIOS while the Elonex comes with the on-board VLB 9400.
