Master of Magic
First post, by DiamondSoul
Whenever I try to use VDMSound on Master of magic it says that I have insufficient memory (impossible). If I try to use DosBox on the game, it just makes the sound all distorted and off-beat.
How can I make the game work with VDMSound?
Thanks a lot for any help 😀
Reply 1 of 4, by Accident Prone
Use search on the forum... you will find the answers you seek.
Reply 2 of 4, by Morandir
Hey,
I was having the exact same problem and here's what I did to fix it.
Create the VDMSound icon, then go under properties, choose advanced, then compatability.
Under the compatability tab, UN-check "Enable DPMI support (DOSX)" and UN-check "Enable CLI/POPF workaround."
Check the soundcard settings under VDMSound, then run the install program using VDMSound and manually set your soundcard. It finally loaded for me a few minutes ago.
Good luck!
Morandir
Reply 3 of 4, by Guest
i am under Windows XP and the advanced options are not showing up when i am in properties, is there any other way to access the advanced options?
Thank you!
Edit: Aha, i found it! Thanks so much for your help it works perfectly 😁
Reply 4 of 4, by Christiaan
Hi
I just managed to get Master of Magic working on an XP computer (finally!) but there is still no sound.
I tried to to what you said but I still can't find the advanced button. Where is it?
I'm a complete moron when it's comes to this kind of stuff, so I need help!
Thanks,
Christiaan
