First post, by tayyare
Just by luck, I put my hands on a free 486 EISA motherboard a few weeks ago. It had a dead Dallas chip (socketed, hopefully) and I was waiting for the last few weeks for the new one that I ordered from Aliexpress to arrive.
Finally it arrived and I started working on it this past weekend. I took my capricious 386DX-40 apart, and rebuild it with the new 486 board. Configuration is as follows:
- CAF Technologies Inc E426 EISA motherboard
- Intel 486DX2-66 CPU
- 64 MB RAM
- SIIG VD1738 SVGA (CL GD 5429 2MB)
- Sound Blaster AWE32 PnP (CT3670 with 8MB RAM)
- 3Com Etherlink III NIC (3c509B Combo)
- Western Digital IDE/FDD controller with multi I/O (came from an HP Vectra 386)
- Adaptec 1540CP SCSI controller
- 3GB Quantum IDE HDD (Driven by Ontrack DDO, BIOS has 528MB limit)
- 3GB Quantum SCSI HDD
- 3.5" 1.44MB and 5.25" 1.2MB Floppy Drives
- LG 52x CD-ROM Drive
I don't have any EISA cards, so everything is ISA.
I installed MS-DOS 6.22 and Windows 3.11 and everything seems to be working nicely, but I have the error messages below during boot, just before memory check:
EISA Configuration Checksum Failure
Sofware Port NMI INOPERATIONAL
Fail-Safe Timer NMI INOPERATIONAL
Since I never ever played with anything EISA before, I have no idea what do these messages mean. I vaguely remember that, there supposed to be some EISA configuration files that need to come with EISA cards, but all my cards are ISA. The board has 2 ISA and 6 EISA slots, NIC and SB are in ISA slots but all the other cards are in EISA slots.
In addition, which one would you prefer for this system and why?
- Sound Blaster AWE32 PnP or Yamaha Audician 32 Plus with Dreamblaster S1
- Cirrus Logic GD 5429 2MB or Tseng Labs ET4000AX 1MB
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 1 of 3, by Disruptor
You need to run an EISA Configuration Utility (ECU) to configure the EISA motherboard itself.
Reply 2 of 3, by Merovign
I'm Jelly, as the kids say. I had an EISA system back in the day.
The parts (boards) seem neither common nor very expensive, you should be able to find some if you like.
The board details are on Stason and TH99 but I didn't find a manual. Ditto on what Disruptor said, but I'm not sure if that's in the BIOS itself or loaded by a key during/before/after.
Check what BIOS and revision you have and look up that manual, until then maybe this will help (there were not too many EISA BIOSes or machines so maybe they have a lot in common?):
https://ami.com/ami_downloads/Enterprise_II_S … Users_Guide.pdf
*Too* *many* *things*!
Reply 3 of 3, by tayyare
Thanks a lot for the help. I'l check and return back.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
