First post, by Azarien
I have a problem with one of my DELL 2001FP.
It won't turn off. If I press the button the screen goes dark, but power LED stays green and I can see that the screen blinks slightly every few seconds as if it wanted to turn itself on.
But suspend mode works fine - if a PC is plugged in and turned off the power LED goes amber and the monitor stays off (suspended). Same happens when I disable the monitor in WinXP resolution settings (two DELL 2001FPs are connected to this PC).
It doesn't matter if anything is connected to this monitor, or if I use the other power adapter. I just can't turn it off. The other monitor works fine.
