First post, by cyclone3d
Take a look at the top product on this page:
http://www.pmasia.com/isa.html
Swap ISA cards without having to power down the system. 😲
And here is the PCI version:
32-bit:
http://www.pmasia.com/pci32.html
64-bit:
http://www.pmasia.com/pci64.html
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 3, by yawetaG
But they won't fit in a normal case and are mostly for testing purposes. Also, being able to do that probably also requires some features on the software side, such as being able to unload drivers without rebooting the OS.
Reply 2 of 3, by derSammler
Hot-swapping is a hardware feature. It doesn't necessarily mean that you don't have to reboot the system.
Reply 3 of 3, by cyclone3d
For the PCI ones, they have re-initialization software that you run. For ISA, I guess it would just depend on if you can unload a driver or if you even need a driver.
YMF7x4 Guide
