First post, by Almoststew1990
- Oldbie
I have picked up a Socket 7 system as you may have seen in the System Specs. I have having a few simple problems with it!
Problem 1: Cards won't fully insert into the slots. It's almost as if the motherboard is too far back / deep into the case and it needs to be brought forward so that the cards can fully insert into the slots. I'm not sure this was an issue I noticed when I took it apart, so it could be something to do with how I've put the case back together. You can see the gold pins sticking out the slot. If I try to screw in the bracket, gold pins will still be visible.
Problem 2: Possibly related to Problem 1 is that the case isn't "square". The case's back panel comes off with the motherboard attached for easy access to the motherboard. This means the case only consists of a top, front, base and rear and it is wobbles back and forth slightly if I push on it. I've remounted the back panel of the base but it is not lining up square. I have to really push on the case to get it to line up and it won't hold that position:
Problem 3: Less of an issue right now but I didn't record what cables go where for the front panel. The motherboard is nicely labelled with reset switch, speaker, HDD LED and a couple of others. However, it has a front panel LED, which looks like this:
Does the power/turbo button go into this, which then goes into the motherboard? Or does the power/turbo button go into the motherboard, which then goes into the LED front panel thing. The Front panel has a LED screen (I saw it say "HI" rather than 100MHz), a power LED, HDD LED and Turbo LED.
