Driver for S3 Trio64
First post, by GabrielKnight123
I had a look at the drivers from the Vogons driver library but im not sure which one to use for an S3 Trio64 EON2AA 86C764X, there are 3 there but the lowest one is for a 765 and if im right mine is a 764 should I just get one from the net or are the ones from Vogons better to use?
Reply 1 of 1, by Jo22
Hi! Afaik, the Diamond Stealth 64 DRAM used the same chip. 😀
In case the Vogonsdrivers aren't working, drivers for 86C764X can also be found here:
http://www.pc-schnulli.de/hardw/gkpci/s3gkpci.html
PS: Which OS you're using on that PC (OS/2, Win9x, 3.1, Linux, etc) ?
