First post, by 386SX
386SX
Offline
Hi,
I am trying a 478 asrock p4i65g mobo with a P4 3ghz/800/1mb and a Enermax eg375ax-ve p24 and checking the bios voltages i found 12v to be 12,3 and 5v to be 5,3v. Aren't they a bit high? Would you prefer a Coolermaster 500w mpx-5001 low end modern supply?
I was expecting lower values. I have others identical models also the not24pin model and all give +0,3 volts in the bios reading. They sure seems to be strong power supplies compared to others that went below the 13v/5v values.
Thank
