First post, by Cobra42898
I've got a system with a genuine Intel (d865gbf iirc) motherboard, 1gb ram, and a Celeron 2.6ghz processor. Someone upgraded and I inherited it. I seem to recall the celerons were roughly equivalent, but crippled with smaller cache. Front speed bus was slower too I think. How slow does this make it compared to a normal Pentium 4? Same as a 2.0ghz? 2.4? Is there anything important that it won't do, or really is functionally different from? As with all my older machines, it's not running any really critical stuff that I'm panic stricken over. I'm just nosy. 😁
Searching for Epson Actiontower 3000 486 PC.
Reply 1 of 3, by BinaryDemon
Tough to make a generalized comparison because there are many different models of both P4's and Celerons. Also the comparison will differ based on the type computing workload you are doing. If you have a prescott based Celeron D, then it has 256kb cache - if its a Northwood Celeron it only has 128kb cache.
With all that disclaimer, I would generally say the difference is a few hundred megahertz - meaning I would guess your Celeron 2.6 ghz is roughly equal to a P4 2.0ghz.
Reply 2 of 3, by weldum
I agree with BinaryDemon
I have in my collection 3 s478 computers: Pentium 4 northwood 2.0, Celeron D 310 Prescott 2.13 and a Pentium 4 Northwood 2.26
in all the test's i've made, the celeron d comes out in last place, except when there's a software using SSE3 (which prescott supports, but northwood doesn't), also in gaming there's not so much of a difference, mainly because older games will run just fine in any of these.
later games will show more fps (just a bit more) on northwood due mainly to bigger cache
only far newer games (2007) will show a little improvement on the celeron over the pentium (but that's because of code optimized for SSE3), but still, these games are too new and they expect newer and more efficient processors, or at least older but faster processors (3.0GHz or more, hyperthreading in some cases and big L2 and L3 caches)
i know that these processors aren't the same and the comparison is a little bit wrong or unfair, but i'd say that, for S478 gaming you should go for the fastest p4 you can get, then a middle-tier p4 (2.26-2.😎 and then you should look for celeron (preferably use celeron D)
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 3, by zyga64
From my experience:
- Prescott Pentium 4 are not much faster than P4 Northwood with the same clock,
- Prescott Pentium 4 are more power hungry than P4 Northwood - Northwoods are much cooler,
- Celerons D (Prescott) are noticeably faster than Celerons Northwoood with the same clock (more cache, and faster FSB)
So I would say - for socket 478 - go for Pentium 4 Northwood.
Celerons D are not that bad anyway. Old celerons (FSB400/128kB cache) are worst desktop processors of its age, even worse than P4 Willamete.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
