First post, by supaplex
Hello everyone,
I decided to update BIOS on my Socket 7 motherboard with a hope of improving system stability. Unfortunately at the end of the update process error message popped out asking me to disable USB...
How can I go about reprogramming the chip now without booting motherboard?
How much would BIOS programmer cost and is it even worth the hassle?
Many thanks for any ideas!
http://www.motherboard.cz/mb/pcchips/M599LMR.htm
Reply 1 of 4, by PcBytes
supaplex wrote:
Hello everyone, […]
Hello everyone,
Try hotflashing the BIOS chip.
This consists in finding another motherboard (not necessarily of the same CPU socket) that has a DIP32 BIOS chip and booting from a floppy to DOS, swapping the chips at the DOS prompt, then starting Uniflash 1.40 and flashing your BIOS file from there.
Worth the hassle? Depends on you. If you want it, you can go down the said route. If not, you can use it for parts.
Reply 2 of 4, by zyga64
If bootblock on flash chip is not broken you may try prepare floppy on another working computer.
format a: /s
Copy bios file and flashing tool on it, and create autoexec.bat with only one line:
flash.exe bios.bin
Turn on computer with floppy in the drive, and it should boot from this floppy (with screen turned off).
It will flash bios, and after reboot you should have working computer. Worth to try...
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 3 of 4, by quicknick
Or get a reasonably cheap programmer like TL866CS (or the newer version that is available now) - it's been immensely useful to me since I got it. Just last evening I quickly revived a MSI K7T Turbo2 that came with a corrupted BIOS...
Reply 4 of 4, by supaplex
Thank you all for suggestions, I will go for the safest/easiest option and invest in EEPROM programmer then. I've heard good thing about TL866CS and purchase value doesn't exceed the value of the board I suppose!
Many thanks again!
