First post, by strucker
Hi! I want to play "Pingu a barrel of fun", a PC game. It's compatible with Windows 3.1, W95 and W98. I'm using Windows 3.1 within DOSBox. The games runs perfect but i want to ask if i can auto launch the game "skipping" the windows startup, i mean, config the autoexec of DOSBox to mount everything and launch the game but without seen the boot screen/desktop of windows 3.1. And how i can autoexit from windows and DOSBox when i quit the game.
Now i do this:
mount c c:\windows
imgmount d "c:\windows\pingu.iso" -t iso
e:\windows\win e:\windows\pingu\pingu.exe
with this, i launch the game but i see the windows boot screen and the desktop few seconds. I wish i could hide this and auto exit when i quit 🙁
Thanks to everyone!
Reply 1 of 15, by Bladeforce
Wouldnt know if it's possible to bypass the brief desktop at boot up but whats wrong with ctrl+f9 to quit?
This page has tips on changing the boot logo
http://www.win31.de/etips.htm
Change it to a plain black maybe?
Reply 2 of 15, by David_OSU
I think what you want to do is to start Windows 3.1 in "kiosk" mode. You do this by changing the shell from Program Manager to pingu.exe. If I remember correctly, you do this by editing SYSTEM.INI and setting "Shell=e:\windows\pingu\pingu.exe".
Reply 3 of 15, by strucker
Bladeforce wrote:
Wouldnt know if it's possible to bypass the brief desktop at boot up but whats wrong with ctrl+f9 to quit? […]
I want to make the game "portable" so i want to automatize when i quit the game then exit from windows and dosbox. I want to make a lot of games portable so i want to learn do that 😊 .
And about bypass the desktop at boot up its just for aesthetic objectives. I don't know if i can edit some .conf or something like that...
Reply 4 of 15, by DosFreak
The runexit tool by Kippesoep may work:
Automate exiting of Windows 3.1 post-EXE launch
http://www.shdon.com/software/tools#runexit
    runexit.zip
    69.99 KiB
    227 downloads
    runexit.src.zip
    1020 Bytes
    192 downloads
Make your games work offline
Reply 5 of 15, by strucker
DosFreak wrote:
that works! but it exits to the dosbox promp. there is way to exit of dosbox too?
Reply 7 of 15, by strucker
Thank you to everyone!! i do it finally. Wish there is a way to "hide" the desktop boot up while the game is loading.
Oh quick question. I'm using the portable version of DOSbox, but when i mount the disk i must do "mount c c:\<path>" what can i write in the autoexec to mount "c" independently of where is located the program?? Because everything works fine in the USB where i do all the process, but when i move to mi desktop fails to mount c because the path. Any idea??
My autoexec is this:
mount c c:\windows
imgmount d "c:\pingu.iso" -t iso
c:\windows\win c:\runexit c:\windows\pingu\pingu
exit
Thanks!
Reply 8 of 15, by David_OSU
If you can get Kiosk mode working, you will skip the desktop entirely. You may still get the boot logo, but you could either change that to a black logo or change it to box art for the pingu game (just need to convert to 16 color and follow the instructions Bladeforce provided).
Reply 11 of 15, by Beegle
strucker wrote:
I found the way to "hide" the desktop!!
And what was it? How did you do it?
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 12 of 15, by strucker
Just edit this in the WIN.ini:
[Desktop]
Pattern=(None)
Wallpaper=black screen
GridGranularity=0
IconSpacing=999999999
TileWallPaper=1
With that, the desktop is black, and the only icon that shows when the desktop load is out of the screen 🤣 .
This is what i do. If you can't see it, isn't there hahahaha.
Reply 13 of 15, by dj_anubis
I found this thread after looking for some info about this issue
I was able to change the logo to black image, BUT, I still get the "license screen" where its says that this windows is registered to "your name"
is there a way to skip this screen also? and go directly to the game?
Reply 14 of 15, by doshea
strucker wrote on 2018-10-25, 17:19:
Just edit this in the WIN.ini: […]
[Desktop]
Pattern=(None)
GridGranularity=0
TileWallPaper=1
That is what I was going to suggest - at least the black desktop part 😀 I think perhaps you're telling it to use a bitmap that doesn't exist, or did you create a black bitmap? You should be able to go to Control Panel -> Color -> Color Palette -> Screen Element: Desktop and make it black which I imagine should give the same effect with less work, I think. I got this in WIN.INI when I followed this method:
[Desktop]
Pattern=(None)
Wallaper=(None)
[colors]
Background=0 0 0
Reply 15 of 15, by yochenhsieh
strucker wrote on 2018-10-24, 20:24:
Oh quick question. I'm using the portable version of DOSbox, but when i mount the disk i must do "mount c c:\<path>" what can i […]
mount c c:\windows
exit
Thanks!
You can use "." to replace current directory of doxbox.exe.
mount c .\[C_FOLDER]
imgmount d ".\[ISO_FOLDER]\pingu.iso" -t iso
exit
Or if everything is just put in dosbox.exe folder:
mount c .
imgmount d ".\pingu.iso" -t iso
exit
