First post, by Baoran
How is compatibility between pci versions? Like can you put PCI 2.2 card into PCI 1.0 or PCI 2.1 slot or other way around?
I have been trying to find this information online but it has been difficult because it gets mixed up with PCIe stuff when many people who talk about PCI 2.0 actually mean PCIe.
Reply 1 of 4, by Strahssis
I just gave the search a try as well and the mix up is really annoying indeed. 😜
I'm pretty sure that an PCI 1.0 or PCI 2.1 card will work in a PCI 2.2 slot, but I'm not sure whether it will work as well the other way around. 😕
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 2 of 4, by Anonymous Coward
Does PCI 1.0 really exist in the wild? The oldest I've seen is 2.0. If 1.0 exists, then it must be relegated to some obscure intel or OEM board. I seem to recall 1.0 was defective in some regard, perhaps lack of busmastering?
From what recall, the PCI slot is designed so that the older cards will normally fit into newer slots and vice versa, but if there is any electrical incompatibility the card should be keyed in such a way by the designer to prevent it from being inserted into the wrong type of slot slot. As to whether or not some low voltage PCI cards were designed with incorrect keying and could potentially be fried by going into a 5V slot, I have no idea, but it is certainly a possibility.
Reply 3 of 4, by Baoran
I always thought that old pci 486 motherboards would have 1.0 since they were the first ones to get pci slots, but do they actually have 2.0?
Reply 4 of 4, by Tiido
1.0 doesn't exist in commercially available stuff, 2.0 is the fist thing available. 2.2 cards do not seem to work in earlier things without explicit support even if voltage support exists.
