First post, by elderago
FINALLY got a motherboard that works and was able to build the computer, now the issue is I cant seem to install windows xp. the windows goes throught the setup process and copys onto to the hard drive but when it restarts it it goes through the usual memory test but will go through set up again
motherboard is a P4845gdbl
I have the cd crive set to primary slave
I have the harddrive set to secondary master
what do I do ?
I now understand what people had to go through back then ide is a pain setting jumpers is a real pain god bless sata !
