First post, by Strahssis
Hey guys,
As some as you might remember, I recently recapped one
of my old power supplies. Now I'm wondering; what actually
causes a power supply to blow up? Is it a result of leaking
capacitors, does one of the transformers explode spontaneously
or something else?
Now my follow-up question; can I trust a power supply
which I recently recapped like a new one? I used VISHAY branded
capacitors. I'm looking forward to hearing from you soon,
Sincerely,
Miko, Strahssis
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 1 of 14, by wiretap
Usually degraded capacitors. Or in the case of physically blowing up, a capacitor that is installed backwards. 😜
My Github
Circuit Board Repair Manuals
Reply 2 of 14, by Baoran
I had one power supply that didn't exactly explode, but I heard some kind of crackle and then there was flames coming out of where the power supply usually suck air from. Any idea what could cause something like that?
Reply 3 of 14, by mrau
better late than never 😁
or something else?
caps are the most sensitive part i believe; i'm no pro in this but looking at some youtube pros i'd say there are chances other parts get damaged too - mostly not visible stuff but changes parameters;
hell no
Reply 4 of 14, by dos9
Use a undamaged PSU if you want to protect the mobo, SSD, GPU, etc.
I recently had a PSU blow up too,
I think it was caused by bottom PCB side of a HDD making contact with metal part of the case and forming a short circuit.
The PSU made a loud puff sound and starting pumping out grey smoke (boiled capacitor electrolyte).
It was a high quality PSU but I am never using it again, I won't even bother repairing it.
Reply 5 of 14, by ODwilly
Strahssis wrote:
Hey guys, Now my follow-up question; can I trust a power supply which I recently recapped like a new one? I used VISHAY branded […]
Hey guys,
Sincerely,
Miko, Strahssis
Well in all honesty it depends on the quality of the unit you recapped. Something like an old Antec Trupower full of Fuhjyuu's is a well built unit, but if it has lots of hours on it with blown caps? Odds are even after a recap there will be components damaged by high ripple, out of spec voltages, ect.
Now you take the same unit that hasnt seen heavy usage or is NIB and recap it and I would trust it no problem. Well as long as you are replacing then with something like a Rubycon vs OST or something.
Reply 6 of 14, by stamasd
In one case, what made one of my power supplies explode was a small amount of black powder. Don't ask. 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 7 of 14, by Strahssis
As I understand the capacitors are the first components to die in a power supply, but the other components take damage as well over time, so a recapped power supply can't fully be trusted anymore, correct? Reading all your comments, I will probably use it for quick testing only, but I will not put it through any kind of long term use anymore. It is not a very high quality power supply, though it is not extremely lightweight, indicating that it isn't absolute garbage either. It's a OEM 250W FSP-Group power supply. 😀
Reply 8 of 14, by PcBytes
Recapping can be trusted, given that you are using high-quality caps (Panasonic/Rubycon/Nichicon/Sanyo) when recapping.
And also, FSP power supplies are actually one of the better power supplies, up there with Delta and Seasonic.
Reply 9 of 14, by Strahssis
Then I might actually use it in one of my builds later on. Not on anything too worthy though, maybe in a Pentium 4 or Athlon 64 build.
The exact model number of my power supply is FSP250-60PNA(PF) and I used VISHAY-branded capacitors. For now I have been using it to test components or configurations quickly. 😊
Reply 10 of 14, by Baoran
Are Seventeam power supplies any good?
Reply 11 of 14, by ODwilly
From what Iv heard on different topics on VOGONS they seem good. I think some of the atx ones used crap caps, but otherwise were well built.
Reply 12 of 14, by Imperious
One method I've come across for blowing up power supplies is an ignorant person switching the voltage from 240v to 110v.
Power supplies don't like that.
Someone I know of actually did this a few months ago.
Reply 13 of 14, by Strahssis
Why did he do that? 😵
Reply 14 of 14, by Tiido
I have seen that happen in a school once where a kid thought it'll make a game work or enable cheats or something.
