First post, by swaaye
I'm trying to get some TIE Fighter going in DOSBOX and I've found your CVS builds to offer performance well above the official .61 release. I can get TIE to run smoothly in SVGA, truly wonderful.
Problem is that my USB joystick isn't seen by your builds, even though they have the joystick patch. 0.61 detects it and it works, and it says the joystick's name in the DOSBOX status window (something that doesn't happen in your build.)
Is there some trick to getting the USB joystick working in these newest builds with your joystick patch?
