First post, by 8088
Hi, I recently got a sharp pc7100 and having problems with the FDD. It was unable to boot of a disk (and the HDD is not working but worry about that later) so I stripped it down and funnily enough I found out the fdd wasn't even plugged into the motherboard. I still decided to remove the FDD pull it apart and give it a lube and clean. I tried the drive in another machine I have and it worked perfectly.
So I reassembled the fdd and put it back into the Sharp PC and was going to use a standard PC fdd data cable. Still getting an error trying to boot (Drive error) so now i'm wondering if the controller on the board is dead or if Sharp used a non standard cable to connect it to the motherboard? So if anyone has a manual with pinouts from the mobo that would be greatly appreciated.
Cheers
tl;dr Does anyone have a manual for the Sharp PC 7100 or know the pinouts to the fdd?
