First post, by rokas_at
rokas_at
Offline
I've tried to run Tie Fighter under Windows 2000 using VDMSound and mouse2kv. The problem is that game requires at least 560k conventional memory, but mouse2kv eats as much as 66k. Even with all residents (mscdexnt, redir, dosx) disabled I was able to free up only to 550k conventional memory. Has anyone encountered such problem and found a solution? Old games were quite demanding for conventional memory and I doubt if only Tie Fighter runs into such problem with mouse2kv.
thanks and br,
rokas
