Trying to get Miracle Piano to run ...
First post, by DonnaNCarolina
Miracle Piano Teaching System, circa 1991. It has a keyboard attached with a MIDI/USB cable and the installation seems to think it is communicating. The program teaches you to play the piano thru a series of lessons. I did have a laptop that I ran the program from, it was Windows 95 (I think). I recently recycled the laptop (wish I hadn't but it didn't power up).
I am trying to run it on a Windows 10 computer, 64-bit operating system. The program starts and shows the initial logo and a followup screen. It then shows a stopwatch and gets stuck. When I monitor it under the Task Manager, when the initial screens start, it runs about 30% of the CPU. When it hits the stopwatch screen, the Task Manager shows it to be using less than 1% CPU. It just seems to hang at that point.
I've tried modifying CORE, CYCLES and CTL-PF8 to increase frames. Also checked that all files are not marked as read-only. Nothing seems to help.
Any suggestions appreciated.
Reply 1 of 14, by Jo22
Hi, sorry for the late reply! I wish you a happy new year!
I'm speaking under correction, but I think DOSBox only has MIDI-out for now in order to support MT-32 and other MIDI modules.
In order to fully use a keyboard, you'll need a MIDI-in support, as well.
Edit: You may have more luck using PCem or 86Box with Windows 98SE installed inside.
Or Qemu, which also supports a Sound Blaster 16. Not sure though, if Qemu supports MPU-401 emulation.
If not, just use any emulator/virtualizer that either has MIDI support for native DOS or can run a
32-Bit Windows that has the ability to emulate MIDI support for DOS applications.
Reply 2 of 14, by DonnaNCarolina
Thanks! I’d pretty much given up. I did buy a cheap laptop running Windows 7 in 32-bit mode but didn’t get any farther. Guess it’s good I haven’t packed up everything to head for EBay! I’m not a PC person so I’ll go do some research on your recommendations.
I appreciate your taking the time to respond! Will let you know if I get anywhere with your recommendations.
Reply 3 of 14, by Jo22
You're welcome! 😀
Note that Windows XP (x86) was the last release to support MPU-401 and sofware-synthesizers (via DirectMusic/DirectX) out-of box.
Windows Vista and later simplified MIDI support. To change your default MIDI device, an extra utility like Vista MIDI Picker might be needed.
That being said, I have rarely used DOS software on Windows NT (I assume it's a DOS program since it is from 91)..
If you're looking for a new old machine, probably any computer with a soundcard that has got a 15pin game port might be useful
Providing MPU-401 support in real DOS or Windows 98SE is not as tricky as trying to get Sound Blaster sound working.
It doesn't matter if the card is connected via ISA or PCI, aslong as it is visible for/detected by the PC or laptop.
A MPU-401 type MIDI interface (UART mode) is comparable to a serial port (COMx).
Edit: Another thing that comes to mind - Some USB-MIDI cables I have seen had a confusing labeling.
They sayd "MIDI IN" and "MIDI Out", when they really meant to say TO MIDI IN and TO MIDI OUT.
Switching the cables worked for me back then. Also, better cables have built-in opto couplers..
Reply 5 of 14, by Jo22
Good luck! 😀
Also have a look at SoftMPU. It "emulates" a fully functional MPU-401 including the Intelligent Mode.
It works fine for everything in DOS, except Protected-Mode games.
Even better, SoftMPU also supports serial ports.
There used to be a hack, I remember, which allowed to change any simple rs232 serial port to MIDI-compatible baud rate.
It involved changing a crystal, I recall.
Alternatively, there's HardMPU project.
That being said, better check if these also support receiving data from a MIDI device already,
since I never tried this so far with a keyboard before (sorry).
Reply 6 of 14, by judkei
I was able to install the DOS version of Miracle Piano on a laptop running Windows 7. The program runs fine EXCEPT there is no sound. I use DOSbox .74 and the DBGL front end to run the program.The computer has a built-in sound card and does not have any serial ports. I am connected to a Yamaha NP-12 keyboard and have verified the MIDI connection works fine with modern MIDI windows software. Any suggestions as to how to fix the sound problem.
Reply 7 of 14, by Jo22
Hi, may I ask you if you did check the DOSBox config file already ? 😀
Sometimes, the MIDI device is configured wrongly.
You need either default or Win32 and you need to specify which device numer you like to use.
In DOSBox, you can check the current config by typing: mixer /listmidi
    9.51 KiB
    31.55 KiB
Reply 8 of 14, by BravoSierra
I have a working installation of the Miracle Piano Teaching System running on an old DOS Compaq PC, a soundblaster and a Yamaha Clavinova.
It's fun to use it with my grand children, but unfortunately would one of the parts of that puzzle fail, I would not be able to reinstal it. Have tried to install it on a windows laptop but I could never connect the midi cable to a USB port,
Also, once I've try to connect another midi cable, and it did not work. So I believe that not every midi cables are the same, although they look similar. so for some reason it's only working with my original midi cable.
Best chance,
Benoit
Reply 9 of 14, by chrisost
I just started down this rabbit hole, too.
The DOS Miracle program has two ways to connect to the keyboard:
  1. Through a serial port using the (proprietary) serial to MIDI cable that came with the keyboard
  2. Through the PS/1 MIDI port
Using a USB to MIDI converter could work, if the emulator running the Miracle program emulated the PS/1 MIDI port. Unfortunately this isn't supported by DosBox - it only supports MPU-401 (which is a different hardware interface).
Theoretically, a USB to serial adapter would work if used with the original serial cable. There seem to be folks that have done this successfully. I don't have that cable to try, though there is a purported pinout for it.
I don't have the Windows Miracle program (though would love to get my hands on it!) to know if it would work with an emulated MPU-401 and a USB to MIDI cable.
I'd also be interested to find documentation for the PS/1 MIDI hardware to see if it's possible to add support for that to DosBox (and so get the DOS version working).
Reply 11 of 14, by Shreddi
Nedhal wrote on 2021-04-13, 17:58:
Wonder if anyone here was able to get miracle piano to run?
I purchased a copy of Miracle Piano on Ebay that ran on windows. I had to dumb down an old laptop to win 7, use the midi to usb and it worked great. I am hoping someone will convert to win 10. I had the original miracle piano when it first came out on the 5 1/4 floppy disks. Miracle Piano is the best piano teaching system I have ever seen by far. If anyone has discovered anything close to Miracle or ? please post. Thanks.
Reply 12 of 14, by Shreddi
I guess this subject is dead. I will dig out the old laptop I dumbed down to run it again. Anyone interested in the very best piano teaching program that ever was? Miracle Piano is it. It's too bad learning software is not as popular as games. Even though Miracle Piano is kind of a game.
Reply 13 of 14, by pjay1980
Shreddi wrote on 2021-11-26, 05:17:
Hi I'm amazed that you had this up and running I tried a about 8 or so years ago and couldn't get it working.
Very keen to chat more about this
Reply 14 of 14, by Jimmah03
pjay1980 wrote on 2023-02-19, 08:48:
For anyone that was still attempting this. I was able to successfully get it working using the latest version of DosBox, the original miracle piano serial cable, a usb to serial FTDI cable (set to 32800 baud). The trick in the dosbox configuration that finally got it for me was setting the CPU to 486_slow.
With that the Miracle Piano software loads and plays out on the piano without any issue. I was able to go through a few lessons and even help some aliens arrive!
Any questions feel free to send them my way. The setup is at my parent’s house so I might be a little slow on the turnaround if it is more technical than I can recall off hand (seeing how long this thread has survived, I trust that won’t be an issue).
