First post, by Technomancer21
So I've got an awe32 installed in my retro box, and it's running dos 6.22 / win 3.11, and I'm just wondering what applications are supposed to be installed on the win 3.11 side of things.
I've got the awe32 control panel and three other items, but as I recall from a soundblaster 16 install some time ago, isn't it supposed to have media playback software bundled with it?
If not, is there any chance someone can suggest such software I can install instead?
Reply 2 of 5, by Technomancer21
Cheers my friend!
Reply 3 of 5, by Technomancer21
hang on a sec, this is for the CT3930, mine is a CT3910, will that make much difference?
Reply 4 of 5, by jesolo
No, you can even use the AWE64 installation CD, which will sometimes give you newer versions of the bundled software (like Aweutil).
Reply 5 of 5, by chinny22
SB16 though to the AWE64 share the same drivers, main difference is if the PNP util is needed or not
Creative still have drivers as well if you want to poke around
https://support.creative.com/Products/P ... tegoryID:1
