First post, by Arbys Guy
So i just finished getting this motherboard working with pIII 500 mhz cpu normal switch settings working at 100 fsb
the hardware i have on the board is
Macron mpt-400 ATX
Slot 1 Pentium III 500mhz SL37D
2 256mb double sided 133mhz sd ddr
AGP GA-622-32C (nvidia tnt 2)
pci2/pci3 slot - x2 voodoo 2 sli
isa2 Creative CT4380 awe 64
isa3 Yes! Netware 2764
Do the other cards matter when bringing the fsb to 133 besides the video cards?
i tried to just simply change the switch settings according to what i thought would be just over 500mhz on the cpu but it posted 6..somehting mhz i think it was 650.
Diddnt want to try again because it froze then wouldnt boot until i changed it back. i tried 133 x4 switch setting.
here is the bios it has default values loaded maybe there is something i need to change in here?
