First post, by renojimmy
Hello, first time poster. I spent a couple hours yesterday searching this forum trying to find if anyone ran into a similar issue. I have an AT computer case and the LCD front display is parked at a set integer. If anyone has links to a post that may be a duplicate, please share. I took some (bad) pictures.
The computer is an AT pentium 2 slot 1 mobo 66mhz fsb from around 1998, and the case I believe is a bit older. It's an Elpina slot 1 i440lx motherboard, if anyone can help find the manual that would be great. I believe this may be a a copy paste clone of another mobo.
There's no turbo setting on the pinout where you'd typically find it on a 386/486 motherboard, and there's certainly no dip switches for setting the lcd. I'm wondering if this AT computer case was purpose built to interface with jumper settings on a specific motherboard? I'm guessing that at some time 20 years ago this LCD displayed a 133 or 200 or whatever, but right now it's just showing 455 🤣
