First post, by Anonymouse
As far as I can see, the start command wont allow you to specify arguments, i.e. -conf. If you did something like
start /high "c:\dosbox-0.61\dosbox.exe -conf default.conf"
you would get an error because the start command would assume 'dosbox.exe -conf default.conf' is the name of the file to be run. If you tried
start /high c:\dosbox-0.61\dosbox.exe -conf default.conf
it would try to parse -conf as an argument for start and not dosbox.exe and not load the conf file.
Can anyone tell me either the correct syntax of start to get around this problem or the default configuration file that dosbox loads if none is specified?
