First post, by GabrielKnight123
I haven't used a CRT monitor for years and now I have one up and running but the image is "interlaced" to put it or another way to explain the image is its like scan lines from some emulators options, the image seems to have black horizontal lines not really bad ones but it might be that I haven't used a CRT for so long and that I'm used to LCD type monitors, I have seen three dials on the flyback transformer and some sort of adjustments on the tube neck would any of these settings remove the "scan lines" that I see?
