Ok... Here's to all the people trying to get MoM working with sound and music (THIS DOES NOT FIX THE COMBAT PROBLEM!!! I turn sound effects off *OR* run the stat based combat instead)
Command Line: %VDMSPath%\VDMSRun.bat magic.exe
Starting Dir: c:\MPS\MAGIC (Edit obviously)
Memory: All set to auto
Now, here's the fun part. Under Advanced in the properties, you can set Compatible Hardware Timer and custom Autoexec.bat and config.sys files. I created one of each. Here they are :->
Autoexec.bat:
@echo off
Yeah, that's it. This way *NOTHING* gets loaded, yet since the file is there, it FORCES nothing to get loaded.
Config.sys:
device=%SystemRoot%\system32\himem.sys
files=35
dos=high,umb
Ok, hope this gets everyone up and running. Maybe I should put this some place for future reference :->
