First post, by appiah4
I acquired a Socket 7 motherboard not long ago.. Aside from a few missing capacitors, it also has a broken coil choke. It seems to me a ferrite bead of 12mm external 8mm diameter with a 12 loop copper coil around it..
I don't know how to determine (or guesstimate) the rating of this part, where to source it, and whether there are any suitable modern replacement component types for it as this type of component seems to be rather rare in supply and totally not used on newer parts (so something else must be used in its place?)
Can someone advise me on what to replace this with?
    390.33 KiB
Reply 1 of 13, by root42
I am not an EE, but maybe you can simply get hold of another ferrit core and make your own inductor? You need new wire, make sure the insulation is not scratched, and then make 12 turns from the looks of it.
According to a coil inductance calculator (http://www.66pacific.com/calculators/coil-ind … calculator.aspx) My guess would be that this coil has roughly 1mH inductance. You can probably also get a commercial replacement, which looks slightly different. Not sure about other properties though, but the large gauge wire suggests that it has to withstand rather high currents.
YouTube and Bonus
Reply 2 of 13, by Roman555
I would try to find replacement on others damaged mainboards. A toroidal core of chokes are marked by colours. Colours depend on permeability.
So you just have to find a choke with the same size and colours, the same quantity of turns of winding and the same thickness of wire.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 3 of 13, by gdjacobs
You can measure L for the choke:
https://daycounter.com/Articles/How-To-Measur … nductance.phtml
Ferrites are variable in mu, so calculating isn't going to be accurate.
Reply 4 of 13, by appiah4
Sounds like too much hassle for a PCChips board I'm afraid 🙁
Reply 5 of 13, by tayyare
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 6 of 13, by Roman555
I think the material of the core of the choke isn't ferrite. They are called iron powder cores.
Reply 8 of 13, by gdjacobs
I would expect an iron powder core to similarly have issues with variable mu. Best to measure the inductance directly.
Also, don't forget to measure DC resistance of the coil to factor in.
Reply 9 of 13, by appiah4
All this is impossible for me to do if only for the fact I dont know how to do half of them.. 🤣
Reply 10 of 13, by gdjacobs
Measuring DC resistance can be done with the ohms setting of your multimeter. The other requires the use of an oscilloscope. You might be able to generate the test signal with a high def PC sound card, but I'd recommend using a signal generator in case you require higher frequencies. Let me know when you have access to those tools* and I can explain how to do the test step by step.
* check for any local maker spaces, ham clubs, or local universities and colleges if you don't want to purchase
There's a current analog of the capacitor voltage decay method which could also be used for measuring inductance.
Reply 11 of 13, by nforce4max
For a rough and quick repair just replace with another coil of similar size and possibly same or similar number of turns until you can find a proper coil. I've done double coil and double cap mods to improve overclocking as well just for fun on hardware that was recent up to 2010 or so and had no issue.
Reply 12 of 13, by appiah4
Can I measure the dc resistance on the circuit or donI have to remove it?
The second will have to wait as I have no oscilloscope 🙁
