Virtual MIDI PC?
First post, by furan
I've read a few threads that have mentioned setting up a second PC running software to act as a virtual MIDI device, instead of buying expensive sound hardware - are there any instructions on how to do this? I tried digging around. 😀 Ideally I'm looking for something that can respond to SYSEX commands to switch between different virtual synths (or maybe hardware I have in the virtual MIDI machine).
Thanks,
-Ian
Edit: Found Phil's excellent tutorial, still watching: https://www.youtube.com/watch?v=vSk9S1bkRS8
Reply 2 of 3, by Falcosoft
Also here's a video about how preset switching can work with the help of SysEx messages:
https://youtu.be/6CdJ7sEt8UM
And some preset switching mid files from Kamerat:
(You can extract syx files from them if you want by FSMP itself: Event viewer/debugger -> File -> Save SysEx data from Midi)
Or you can download the tool+syx files directly I used in the video from here:
download/file.php?id=34344
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 3 of 3, by furan
Thanks!
