First post, by ZoomPicard
Recently acquired a
COLORGRAPHIC COMMUNICATIONS CORPORATION
SUPER DUAL VGA
16bit Isa Card
The attachment Dual Vga Card.jpeg is no longer available
Here are the full tech specs:
http://arvutimuuseum.ee/th99/v/C-D/50144.htm
I suspect these are early CAD based cards.
On boot you get standard does output on one of the connections on the other you just get the video bios boot screen
The attachment Video Bios Screen Second Monitor.jpeg is no longer available
Does anyone know what software would be required in Dos or windows 3.1 that enable the second monitor?
Reply 1 of 6, by vlask
Dont think they were for cad. Driver support for W3.11, W95, WNT....
http://web.archive.org/web/19961101040548/htt … om:80/warp.html
Sadly for you web archive didnt archived drivers, but theres at last names of zip files. You could try google them, or try later archived versions of pages. Your card belongs to Warp series.
http://web.archive.org/web/19961101040203fw_/ … 80/techsup.html
Edit: this one might be your lucky one.... looks like drivers were archieved....
http://web.archive.org/web/20000611204621fw_/ … vigdrivers.html
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 2 of 6, by root42
You should put a sticker on that EPROM, or UV exposure from daylight might gradually erase it...
YouTube and Bonus
Reply 3 of 6, by jaZz_KCS
These weren't specifically for CAD software, albeit usable. You will only be able to initialize the second screen under Windows (3.11, 95 and NT), not plain DOS.
Reply 4 of 6, by xjas
jaZz_KCS wrote:
[...] You will only be able to initialize the second screen under Windows (3.11, 95 and NT), not plain DOS.
It looks like there's duplicates of everything, even the Vesa Feature Connector 😜, and the second chip is active at boot as shown in the photo. Couldn't you just start writing bits to the second chip's registers & framebuffer if you knew where they were mapped? Windows's video access isn't magic.
Reply 5 of 6, by jaZz_KCS
xjas wrote:
It looks like there's duplicates of everything, even the Vesa Feature Connecture 😜, and the second chip is active at boot as shown in the photo. Couldn't you just start writing bits to the second chip's registers & framebuffer if you knew where they were mapped? Windows's video access isn't magic.
Maybe possible, especially since Windows 3.1's video access is far from magic. I wonder if it would be possible to write a TSR that redirects to the second connector?
Reply 6 of 6, by ZoomPicard
Thanks for your input all
I will give some of those drivers ago shortly
In terms of doing development I wouldn't know where to start, I am not really familiar with x86 assembly programming for dos use. I would assume something like TurboC and write C wrapped with some assembly not sure
