First post, by Errius
Does the Intel development code name 'Seattle' refer to the 440BX chipset or the SE440BX motherboard? I see conflicting information about this. Normally Intel gives chipsets and boards different names.
eta: related question - the SE440BX was apparently produced with integrated audio adaptor as an optional extra. Has anyone seen this variant? What is the audio quality like?
Is this too much voodoo?
Reply 1 of 1, by BeginnerGuy
This is not a researched answer but I've always figured SE440BX to be simply a modified 440BX board with a way beefier chipset heatsink and the optional onboard audio, time period reviews would probably still list its chipset as "440BX", since it really is the same. So I believe Seattle refers to all [SE]440BX bearing boards.
Mine doesn't have onboard audio so I can't talk about the second part, I do believe it was a half decent integrated Crystal Audio chip, probably nothing to write home about but good enough for a pair of cheap speakers.
Sup. I like computers. Are you a computer?
