First post, by Windows9566
I just got a AppleColor composite monitor IIe for my Apple IIe, it works but has discoloration on the upper left corner (yellow splotch on the upper left) and lower right corner (blue splotch on lower right)
any way to fix it? or is it there forever.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 1 of 2, by Tiido
Degaussing operation after power on (that thunk sound) should fix such things. This is caused by magnetization of the mask in the screen or nearby magnetic field (i.e from non shielded speakers). Sometimes you need to power on the monitor several times (with few minute breaks) to fix that. Also changing positioning of the monitor while it is running can cause this, in which case another degauss operation is likely needed though effects of that should be far more subtle.
Reply 2 of 2, by sf78
You could also take a risk and use a strong magnet on the case and swipe back from the front side of the case (where the discoloration appears) to the rear where the tube ends. I have fixed a couple of TV's with this method, but it might require a few tries and you might experience stronger discoloring at first. Also, I don't take any responsibility if you make it worse, but if it's already ruined then what's the harm?
