First post, by aurora
aurora
Offline
I'm having the problem where the mouse will get stuck half way across the screen, and to fix it you need to move it back to the opposite edge before it will move the across the entire screen.
I've tried using mouse2kv and it has almost fixed the problem. By that I mean that it will work fine for a couple of minutes, then the mouse will get stuck again. Move it back to the edge of the screen and it will work fine again for a few more minutes. Before using mouse2kv it would get stuck almost every time I moved the mouse (ie. about once every second), so obviously it has helped but not completely fixed the problem.
Does anyone have any advice? Thanks
