First post, by dicky96
I am sure some of you guys will have experience of this problem
So I have an ASUS M2N - NM/S motherboard here. It won't boot, it has continuously repeating long beeps. The user manual does not mention that error code but I think it is related to the video card. I tried several PCI-e cards to no avail, however I did notice that without a video card fitted the long beeps start after a few seconds but with any video card in the PCI-e slot the beeps will start after about 20 seconds or more.
I suspect faulty PCI-e slot and the pins do look somewhat corroded. Also I have a similar problem with the DDR2. With a known good stick in slot 1 I get the repeating long beeps (same with no RAM fitted) but wit ha known good stick in slot 2 I get one long beep then the CPU fan slows down to idling speed. Looking into DDR slot 1 I can see one pin is green and corroded so I think that may be another problem.
As I am am very interested in learning component level repair on mobos and GPUs (I already have decades of experience of electronics repair but not computer PCBs apart from a couple of HDD controller boards) I thought this would be an interesting fault to try and fix for educational purposes.
I have some PCI graphics cards (known good) back in the UK so I will bring one of those back with me when I visit the UK next week as I would like to try the PCI slots on this mobo to see if I then get video output. It doesn't have onboard VGA.
Another thought is there could be a problem with VIA VT6308 QFP chip in the bottom right corner - there is some corrosion down there and that chip I did find a datasheet and it says it is a PCI controller - maybe it also controls the PCI-e, I didn't read the datasheet thoroughly. https://datasheetspdf.com/pdf-file/943196/VIA/VT6308P/1
PS why does the thumbnail display correctly on this forum as landscape but the large image display as portrait??? - at least on my PC
Reply 1 of 4, by rasz_pl
via chip is for useless firewire and can be ignored, if you see green inside pcie slot it needs to be replaced, but this is AM2 board, replacements are plentiful and almost free
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 2 of 4, by brostenen
As mentioned, these boards are nearly free to get. Yet if you REALLY want to clean pins, then this is a good solution. No guarantee that it will work in your case.
https://uk.rs-online.com/web/p/contact-cleaners/8232662/
Reply 3 of 4, by dicky96
Thanks guys - Switch contact cleaner I have already, just didn't think to use it. Same goes for IPA. I read somewhere a toothbrush is an ideal tool for this sort of job
As mentioned I want to try repair this motherboard for educational purposes, not the value of the hardware. The fact it isn't of any value is actually in it's favour on this occasion.
The acquisition of knowledge and skills often proves to be a worthwhile investment IMHO 🤑
Rich
Reply 4 of 4, by DaveJustDave
Deoxit. should be in everyone's arsenal.
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
