First post, by dkarguth
I have a 286 based computer with 1 Mb of RAM, and a Soundblaster CT3620. It does not have a 287 coprocessor. Does anyone know if the 286 can handle wav playback at all, and if it can, is there software that will run on a 286 that takes advantage of the soundblaster?
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 1 of 10, by Jo22
Back in the mid-90s, I used Windows 3.10 for that. I had a 286-12 with 4MiB, a PAS16 soundcard and played large
wave files by using media player (sound recorder for short recordings).
Edit: Oh, just noticed you use an AWE ISA PnP card. Maybe the EMU386 + Windows 3.0 MME combo works for you.
That special Tandy release of Win 3.0 MME has a SB16 driver that seems to work in Standard Mode on a 80286 PC, as well.
(Creative was rater 286-fiendly with their 16-Bit Sound Blasters; they required VXDs for Windows 3.1; the 1.x drives always work.)
Edit: There's also playwav: http://www.fysnet.net/playwav.htm
Reply 2 of 10, by dkarguth
Thanks, those sound interesting, I'll try those out. I have never used this card before, is it a very good card? It was a one dollar goodwill find, so I don't know much about it.
Reply 3 of 10, by Jo22
The card is okay. It has PnP, but also a memory expansion socket for the EMU8000 synth (used by 386+ games and some MOD players).
If memory aerves, you need CTCU and CTCM to configure the card under DOS (for ex. AdlIb "FM" is disabled by default).
These programs should load fine with EMU386 (adds a few important 386 instructions to 286 PCs).
Reply 4 of 10, by Scali
Creative used the .VOC format, and they had tools to play those files, which work fine even on an 8088. There was also a VOC2WAV and a WAV2VOC utility included.
So I would suggest converting the WAV files to VOC and then using the Creative VPLAY.EXE tool to play the files.
Reply 5 of 10, by Cloudschatze
Not sure what you're trying to say here. Creative's earlier, non-VxD SB16 drivers are fully-functional in Standard Mode Windows 3.1. Furthermore, and given an ability to leverage the ASP/CSP to play compressed WAV files comparable in size and quality to MP3, I find the SB16 to be very usable in my own 286-class system.
Here's a video even, featuring a 286@10MHz Tandy 1000 RLX system, with 1MB RAM:
https://youtu.be/cPN34XiE5I0
@~9:15, that's Depeche Mode's entire Violator album, ripped and converted to a 4-bit stereo @ 32kHz (256kbps), CTADPCM WAV file.
Reply 6 of 10, by dkarguth
Interesting, didn't know 3.1 ran on a 286. Time to upgrade!
Reply 7 of 10, by Jo22
Hm. Not sure what you're trying to say either, I'm afraid. 😊
Which ealier release of the SB16 drivers are you refering to ?
The earliest ones that I was able to track down were a part of OS/2's WIN-OS/2 package, but they refused to work on my 286. 😢
The bigger was my surprise when I saw that the Tandy version of Windows 3-0 MME shipped with a working 286 driver (hence the tip for the OP).
Technically, it could be possible to use that Tandy driver on 3.1, too. Like after an upgrade, for example.
Providing that Windows 3.1's built-in MCI support doesn't get in the way (3.0 MME implemented MCI differently ?)
Agreed, seems plausible. I didn't say any otherwiise. btw. As I said previously. I used a 16-Bit audio card myself in a 286. 😀
Reply 8 of 10, by mrau
probably not a smart one,but here i go:
whats so hard in playing a wav if no freq change is required?
Reply 9 of 10, by Cloudschatze
I'm using this set, from early 1994.
With "higher-quality" WAV files, there tend to be CPU (I/O), RAM (buffering), and storage implications that can make uninterrupted LPCM playback impractical, or impossible, on lesser systems.
Here is some related analysis I did last year concerning a 386-class system, where you'd participated in the discussion:
"Accelerating" Windows 95 with Creative's Advanced Signal Processor (CSP)
Reply 10 of 10, by Jo22
Interesting. 😮 I must have missed that one. The setup program looks oldschool to me, so this probably is one of the early releases.
Seems to run fine so far in PCem with 286 emulation, as far as I can tell. 😀
Edit: That disk set would be an enrichment for vogons drivers, imho.
