First post, by Rasna
I decided to start restoring an old IBM XT 286 that I had in the attic to get dust and anything else........
The attachment 01.png is no longer available
as I expected it was chock full of dust, so I pulled out the mainboard from the case
The attachment 02.png is no longer available
I start to sneeze again just seeing the picture 🤣
The attachment 03.png is no longer available
After a nice clean with the vacuum cleaner, now it's much better
The attachment 04.png is no longer available
then I finished cleaning it with a good brushing and isopropyl alcohol. It looks like new 😊
now it's time to see if it still works after all these years
The attachment 05.png is no longer available
and it works
My MIDI modules: Roland MT-32 (old), CM-32L, SC-55, SC-55mk2, SC-88, SC-88 Pro, JV-1010, XV-2020, XV-5080 | Yamaha MU-90, MU-100, SW1000XG, MU-2000EX | Akai SG01k | Hammond GM-1000 | Kawai GMega | Korg NX5R, N1R, Triton Rack
Reply 1 of 13, by treeman
I would also open and inspect the power supply, imagine how much dust is in there not to mention check capacitors and output, don't want to burn up that nice board with a powrsupply that may be out of spec now
Reply 2 of 13, by Rasna
The attachment 06.png is no longer available
The post has been successful, obviously the errors are due to the fact that I removed the old battery
The attachment 07.png is no longer available
pressed the F1 key to enter the basic rom..............
The attachment 08.png is no longer available
the video card I found installed is a hercules
The attachment 09.png is no longer available
but not having the monitor, I had to install an old et3000 8bit
Reply 3 of 13, by Rasna
The power supply that I used for this test I had completely overhauled last month 😊
Reply 4 of 13, by Errius
I recently picked up one of these on fleabay but still haven't had time to play with it. It's scattered about the house in a dozen different pieces. I think I heard somewhere that early IBM CGA cards won't work with ATs because they can't handle the increased CPU speed?
"AI Requires Proof That You Are Human"
Reply 5 of 13, by Rasna
If works a crappy hercules, I don't see why a CGA even if it's an early model won't work.........
Reply 6 of 13, by Rasna
The attachment 10.png is no longer available
I will clean the filthy "M" keyboard when I have finished to test everything and putting back into the case
The attachment 11.png is no longer available
removed the dust from the serial/parallel card and tested it
The attachment 12.png is no longer available
the floppy/MFM controller cleaned up
Reply 7 of 13, by Rasna
while I was waiting for the motherboard was drying, I connected a motherboard 386 that I just finished fixing to test the type 2 HDD brick
The attachment 13.png is no longer available
incredibly, the disk motor started spinning without hesitation, passed the bios test and booted as if nothing had happened
The attachment 14.png is no longer available
DOS 5....... too recent for this pc 🤣
The attachment 15.png is no longer available
now some serious tests
The attachment 16.png is no longer available
and this too has passed without errors
Reply 8 of 13, by Rasna
now the most comprehensive test
The attachment 17.png is no longer available
The attachment 18.png is no longer available
The attachment 19.png is no longer available
The attachment 20.png is no longer available
completed after 5 hours........
The attachment 21.png is no longer available
no bad sectors......... incredible !!!!! 😲
Reply 9 of 13, by treeman
thats pretty amazing! very nice
Reply 10 of 13, by dkarguth
not necessarily, I recently attempted to use an original IBM CGA card in my 286 build and it flipped out. It sort of worked, but it got hotter than I was comfortable with and it also didn't behave with some programs.
[SOLVED] DOS programs refuse to use CGA graphics modes
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 11 of 13, by Murugan
Ohhhhhh I've been looking for a 5162 for months :p
GL with the resto.
Reply 12 of 13, by Scali
I don't think that's true.
What is true is that CGA cards do not have an onboard crystal, so they rely on the OSC signal from the ISA bus, which should generate a proper 14.32 MHz NTSC clock.
Some AT clones might not generate the proper clock, which would cause sync problems between the CGA card and the monitor. But I would expect the original IBMs to work properly. In fact, I believe CGA was even one of the video options that the 5162 and 5170 were sold with.
Reply 13 of 13, by Errius
One thing I notice with this computer, in factory configuration, is severe crowding of the I/O card, drive cables and drive controller card. So much so that the drive controller card is physically warped. Bent in an arc. (It's not just my machine, googling images of other units on the internet shows that this deformation is common.)
