First post, by appiah4
Does DT run on Windows 95? Does it need a certain version or patch level?
Reply 2 of 5, by appiah4
DosFreak wrote:
Daemon Tools 3.47
Runs on all Windows 95 releases or just OSR2.x?
Reply 3 of 5, by DosFreak
95B+
You'll need:
USB supplement
Installer 2.0
IE4
95+
You can either see if you can copy and paste files to see if you can get it to work on 95a or try older versions.
Virtual CloneDrive 5.4.4.0 works on 95a.
Make your games work offline
Reply 4 of 5, by appiah4
Thanks!
Reply 5 of 5, by DosFreak
It looks like Alcohol 52% and 120% v1.9.5.3105 work on 95B+ as well if you want something slightly newer. The oldest ver of Alcohol is incompatible with <95B. Probably the same with Daemon Tools as well. It's due to the driver they use. These are trial versions so you'd have to purchase a copy for the non-trial ver. Looks like activation still works on Windows 98.
