First post, by keropi
Hiya!
I have this really old 386 16mhz motherboard that I would like to test:
and this is as far as the boot process goes:
I have no idea how to enter the BIOS setup. I tried the keyboard combos I could google but they do not work.
ALT+CTRL+DEL does reset the board so the keyboard is not locked...
Any ideas? 😕
Thanks! 😎
🎵 PCMIDI mpu site buy+info
🎧 WIP Orpheus soundcard site
Reply 1 of 18, by tayyare
I hope it has not a floppy driven BIOS setup like older 286s and oldest 386s.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2 of 18, by keropi
I will connect a floppy and see if the board tries to read from it
Reply 3 of 18, by Jo22
keropi wrote:
Any ideas? 😕
Hi Keropi, there's one thing that comes to mind - try provoking a keyboard error.
On my 286 with a Schneider-BIOS (Phoenix based), pressing ESC during power-on causes a sticky key error.
Reply 4 of 18, by Scali
My Commodore 386SX-16 had a Phoenix BIOS, and you could enter its setup by pressing CTRL-ALT-S, if I recall correctly.
This site lists some other options:
https://www.lifewire.com/bios-setup-utility-a … cturers-2624461
Reply 5 of 18, by keropi
just by connecting a floppy I got this screen, I could now press F1 and the board booted . Ofcourse like you people said I most likely need that setup program - no idea where to get it though.
at least I loaded DOS 😁
Reply 6 of 18, by Murugan
Try CTRL+ALT+INSERT
I had to do that with 386SX-16 system with Phoenix BIOS
To enter the CMOS Setup, press CTRL+ALT+INSERT simultaneously. This will display the
system configuration setup menu. Ensure the configuration is as indicated below. Follow
the instructions on the monitor to change any of the entries.
Reply 7 of 18, by konc
You can always use Gsetup for basic functionality (probably enough for this board anyway...)
Reply 9 of 18, by keropi
^ I have tried all combos in the page Scali listed - including CTRL+ALT+INSERT (does not work, prints some messages about keyboard stuck keys and lines and waits for F1)
I will go the gsetup way and check it out, never used it before 😁
Reply 10 of 18, by Murugan
Have you tried it a few times, like during or after the mem check? Mine didn't work every single time too :p
Like you need to do it at a specific moment.
Reply 12 of 18, by keropi
@Murugan
yes, pressing any key combo on boot produces a kb error
@quicknick
mega-thanks for that! SETUP and ATSETUP worked for me and the board now boots without issues 😀
really slow system though 🤣
Reply 14 of 18, by keropi
yes, I am not surprised this mobo is really old. and slow.
Reply 15 of 18, by Murugan
TBH I never really tried both of my (identical) systems.
Or just tried Dune for 5 seconds on 1 of them :p Seemed to go pretty well.
These were used as medical equipment for bloodgas analysers.
Reply 16 of 18, by keropi
I did a quick sysinfo benchmark, the board scored 9.08 while the example 386DX/33 system is at ~37 or something ... needless to say this old board has no cache at all 🤣
also these sipp modules are weird - each is 128kbytes? I did not check specs but if you put in the bios more than 1mb of ram you get errors.
Reply 17 of 18, by quicknick
Glad to be of help. That's a low score indeed. Maybe it's working in the non-turbo mode, 8MHz instead of 16? (There are two oscillators near the CPU, 16 and 32MHz).
Also, 128KB for a module is extra-weird, can you find the datasheet of chips on the module and do a quick math on their size? I don't even know if it's possible, but maybe it's accessing the RAM at 16-bits only, thus only seeing half the capacity?
Reply 18 of 18, by keropi
I will look at the ram specs tomorrow since I left the office...
about speed I think that's the 16mhz score, both cachechk and speedsys report a 15.8mhz 386
