Stars! runs on dosbox ?
First post, by roarkes
I have a spanish compilation, named Puntosoft Interactive, with Stars! and Tactical manager 2. I tried to run from dosbox command line, the executables found on INSTALL folder. Doesen't work.
From theyr manual (the DOS word is highlighted by me in text application, PDF-XChange Editor) they give advice for Windows 3.1
Should i try this ?
DOS batch file can be a way, but they don't explain further.
Doom4ever
Reply 1 of 1, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Isn't this clear? Without Windows 3.x it can't run in Dosbox. Stars is not a Dos game (as the installer states explicitly).
You can however install Windows 3.x in Dosbox and then run both
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
