How to edit configfile?
First post, by Guest
This is probably an extremely stupid question, but how do I edit the configfile? The edit-command doesn't do the trick. What am I overlooking?
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
considering the "stupidness" of the question I assume you are a windows user.
Look in the startmenu in the folder dosbox and there you see a link called dosbox.conf
click that one.
Water flows down the stream
Reply 2 of 3, by Guest
Gee, what an idiot am I. I just assumed I had to edit it directly from inside the program itself...
Reply 3 of 3, by Guest
Assuming makes a something something out of you and me, but mainly... you?
