First post, by algernon
algernon
Offline
I need to open and try to edit a bios file with .awd extension..of a FIC 486 VIP IO Motherboard because
if i set the floppy drive for 1.44 3,5", no floppy or cable work...it try to format a 360 Kb instead a 1.44..and fails
not finding first sector etc...
Only with a 5,25" 1.2 MB drive it works...but it's not as usefull as the 1.44 is...
My tought it's a corrupted or bugguy BIOS..anybody encountered this problem? any solution.
The award bios editor cant' open the file..and i don't know how to solve this problem.
https://sourceforge.net/projects/awdbedit/ <------------- the only editor i found..
ftp://ftp.fic.com.tw/motherboard/BIOS/486/486 … -io/427gn2a.zip <------------the bios (the only i found)
thanks for your help.
