First post, by Skanque
Hello Vogons
I have bought this Geforce 2 gts. But I am not sure if its MSI or Creative.
I know that MSI made boards for Creative, but I am not sure if this is an Creative Annihilator 2 or MSI Starforce 815 version of the card.
Hope you can help, so I know how to label my card. Its also an unusual board layout with the smc and capacitors, only card I have seen with that layout is from Chaintech.
Also notice the 157MHz memory clock, what is going on here ?
Reply 1 of 8, by keropi
The sticker on the back says creative and it looks like a creative card. Case closed.
Reply 2 of 8, by Koltoroc
the memory clock is a bit low, should be around 166Mhz IIRC.
Remember, DDR Memory transfers data 2 times for every clock cycle, so the actual clock speed is half of what it is marketed as. For example, a "266Mhz" DDR module only runs at 133 Mhz, but doubles the bandwidth so it has an effective data rate equal to a hypothetical 266Mhz SDR module. Marketing shorted that to 266Mhz DDR which is technically wrong and misleading.
Reply 3 of 8, by lost77
Creative cards I have seen from that time were produced in Singapore, MSI cards in Taiwan.
The ID identifies it as a MS-8820 (MSI Geforce 2 GTS 64MB) although it seems to only have 32MB (MS-8815).
My bet would be on it being an MSI card.
Peeling off the stickers on the front of the card might seal the deal.
Reply 4 of 8, by Skanque
Well, i am not that sure. Despise the sticker, since my other creative cards got another kind of sticker and a "CT" number. Plus they identify as Creative in GPUZ.around 166Mhz IIRC.
Other Creative card:
I think you got it mixed up. The DDR is double as you say, so the effective clock is 157Mhz x 2 = 314Mhz (:
So mine is only 314Mhz compared to the 332Mhz it should be.
Reply 5 of 8, by lost77
Singapore and copyright on PCB, looks like a Creative card.
Reply 6 of 8, by Skanque
lost77 wrote:
Creative cards I have seen from that time were produced in Singapore, MSI cards in Taiwan. […]
This is where it get confusing, because I have a Geforce 4 Ti4600. From Creative, with the sticker on the fan and all. But the card also have the same stickers as my Geforce 2 gts.
All the MSI tell tell signed. MS-XXXX VerXXX number, N1996 ect. Plus it identifices as such, a MSI card.
Where MSI really that sloppy, when they produced cards for Creative ??
Reply 7 of 8, by lost77
I don't think these card were produced for Creative as such, MSI just had a bunch of cards manufactured and then sold them in retail or OEM or to other vendors that rebranded them.
For the consumer it sucks of they buy a brand they like only to find out it is just a sticker 🙁
Reply 8 of 8, by Skanque
I think you are right. And as a collector it sucks that much more. Since I don't have the boxes, cds ect. that would help to further enhance the "Creative" feeling of the cards.
