First post, by buckeye
Just wanting to try this for an exercise as I already have the GOG/quakespasm version working on my Duo Core 2 setup.
My setup is this: PIII 850mhz 256MB ram
Geforce 2 Ultra 64MB
Voodoo 2 SLI
Win98SE
Now getting GLQuake working in DOS do I have to use the V2's or the Geforce or does it matter? Regarding the Glide
driver do I have to put a copy of it in the Quake directory to access the higher resolutions? I remember trying the shareware
version with just the Geforce card and couldn't get it to run above 640x480, even with putting in the settings via command line.
Keep in mind I'm not going to try and convert the GOG version like in Phil's video but plan on getting an original disk and going
from there. I'm not very "hip" on DOS so any tips would be welcome!
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 2 of 5, by rasz_pl
windows only
you can play quake 2 using Voodoo tho Quake 2 DOS with 3DFX Rendering [56k Warning]
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 3 of 5, by buckeye
Ok, so GLquake is windows only learn something new everyday.
So can anyone help me with my concerns with setting the game up so I can play with resolutions other than 640x480?
Reply 4 of 5, by bofh.fromhell
Tried editing the shortcut ?
Like:
glquake.exe -width 1024 -height 768
Oh and you have a file called opengl32.dll in the quake directory.
Thats the 3DFX minidriver.
If you want to run glquake with another renderer (like geforce) just rename the file (i prefer opengl.3dfx =).
Reply 5 of 5, by buckeye
bofh.fromhell wrote:
Tried editing the shortcut ? Like: glquake.exe -width 1024 -height 768 […]
Like:
Thank you, just what i needed!
