First post, by tabm0de
- Member
"Im trying to created the image which the compaq presario 625/633 came with, i managed to get the 19 of the 20 disk images that was created with "saveall", i am restored the pc with work around to get everythinkg work except ms works, so i am now look for any one that has the swedish version of microsoft works 3.0.0.263 ( 3.5" 5 floppy's ) to create the real harddisk image that came with the compaq presario 625/633 and also possible to create the original 20 floppy "saveall" image."
I managed to use the 5.25" images to just copy the files that was missing for msworks, so now i have a original image of Compaq Presario 625/633 as it was delivered from the start.
Some changes was needed since controller drivers for drives like western digital and seagate was added in windows\system.ini which generated a error when one of those disk was not used.
After fixing these points i could create a new original floppy restores disks with the compaq "SAVEALL" Utility.
naa, nothing yet...
