First post, by retardware
I have bought a nice 17" late Trinitron multisync monitor for making the retro gaming feeling a little bit more authentic.
As the "new" monitor supports up to 70kHz horizontal, now I am trying to remember which graphics cards allowed me to set custom frequencies in DOS, to avoid flicker.
If I remember correctly, this was common with the Spea V7 cards, these had such an utility which allowed you to adjust and memorize the frequencies for all text+graphics modes. It looked very similar to Suse Linux' sax utility.
So my question:
Which graphics cards/chipsets offer drivers/utilities to manually set the refresh frequencies for the graphics cards modes in DOS?
Reply 1 of 5, by elianda
Actually nearly all of them.
CL -> CLMODE
S3 -> S3REFRSH
Trident -> VMODE
VBE3 -> integrated in standard
Youtube Channel
Reply 2 of 5, by keenmaster486
I have a very similar monitor and I was wondering the same thing.
On this same note I wonder how many DOS programs and/or games have the option to set the refresh rate without needing an external tool. I honestly don't remember ever seeing one.
World's foremost 486 enjoyer.
Reply 3 of 5, by elianda
The reason is that for all cards before VBE30 support the refresh rate enforcement is a proprietary feature.
Youtube Channel
Reply 4 of 5, by Scali
Yup, and VBE 3.0 was released in late 1998, by which time Win9x had taken over, so VBE 3.0 was too little, too late.
Reply 5 of 5, by elianda
Also notable is that some more professional graphics cards, like Spea Mercury run higher frequencys by default for certain modes, like 640x480 at 85 Hz. If you want to use those with a 60 Hz TFT in these modes you have to force them to do so by the tool or your TFT will not sync. Also some do not support 60 Hz for some low res modes at all as it was considered obsolete for professional usage.
Youtube Channel
