First post, by GhostyGhost
- Newbie
Hello everyone,
Recently been trying out some games on my newly rebuilt Windows 98SE PC but been having some issues with certain games.
One of them being Nocturne 1999. A good ol favorite of mine.
Problem is, it keeps giving me a "bright" but black screen when I start up the game and promptly freezes the PC.
I applied the Nocturne Patch 2 and still nothing afterwards.
This is very similar to my previous thread regarding Frogger 1997 but more different as that game had a loading screen before forcibly restarting my PC.
Here are my specs on the Windows 98SE PC.
RAM: 512MB
GPU: Modded Voodoo 5 5500 (Voodoo 5 6000 VSA-100 chips at 128MB)
CPU: Pentium III 1GHz coppermine
Thank you.
EDIT: I solved the DirectX/Direct3D problem. The system was constantly attempting to use SLI mode on the Voodoo 5 5500 and that has problems in Direct3D. So after a few software installations such as a more updated 3DFX tools, I set the Direct3D mode to Single Chip Mode and that solved my problem.
So my big mistake was not noticing that SLI mode was enabled. What a annoying mistake to assume it was off from the beginning. Well anyway I hope that this EDIT clarifies what the issue was for DirectX/Direct3D. But now I will have to find out what's causing the 3dfx glide to not work properly as Diablo 2 confirmed Direct3D is now fixed but now glide has been another issue causing this issue. More to come soon.
EDIT FINAL: The problem has been solved. It was a hardware problem with Voodoo 5 5500. It is now fixed and all is well now.
If life throws a wrench into your plans, then show life that no matter what it does to you, you will always prevail.
