Reply 1 of 2, by retardware
retardware
Offline
- Oldbie
wrote:What happen if I plug the module with wrong orientation?
In a recent similar thread it turned out that the modules have their power supply pins symmetrically. Thus in case of reversed insertion it is unlikely that you'll notice bad smells. It then just does not work, and you then know you have to try the other way around.
Reply 2 of 2, by muon
muon
Offline
wrote:wrote:What happen if I plug the module with wrong orientation?
OK No burnt!! 😀
