First post, by tayyare
I recently grabbed that Cooler Master Cavalier 2 CAV-T02 case/chassis.
159.31 KiB
It has a analog VU meter but available information about it is very slim to say the least. It supposed to come with a bracket that should somehow connect it to a souncard's or motherboard's speaker jack, but it is missing.
I found a low res picture of the accesory, and a manual for similar but different case
36.63 KiB
160.16 KiB
113.57 KiB
http://www.google.com.tr/url?sa=t&rct=j&q=&es … 9LSOR_HfzL1lF7t
And here is the picture showing VU meter PCB and where the input should go (3 pin male connector at he left, just under the power molex):
118.98 KiB
What do you think? If I just somehow connect the speaker out from the board (Left channel, right channel, ground) driectly to this, will it work?
Or this mising black box/backplate combo is not a simple breakout box, but has a PCB hidden inside that supposed to make some kind of a conversion?
Thanks in advance 😊
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 1 of 7, by mdog69
Whatever is on the back panel, it has to be passive - the only connections appear to be the two 3.5mm connections exposed on the back plate, and (looking at the cable) a 2.5mm plug inside the case which then connects to the spare connector below the molex power connector.
Can you:
1) Extract the VU meter PCB from the case, and take a clear photo of both sides of the PCB
2) Confirm the markings shown on the integrated circuit U1. (no picture required for that bit - just read it and tell us what it says.
3) Trace where JP1 and JP2 cables go to
The VU meter board doesn't look complicated, and it might be possible to deduce a circuit diagram, and from that confirm/guess what the contents of the rear panel connector were.
(My only concern is that the "common" connection from a PC speaker outlet may not be at ground level - especially if the speaker amplifier is "bridged". In this situation connecting the common to the PC 0v line might stop audio output working)
Reply 2 of 7, by tayyare
mdog69 wrote:
Whatever is on the back panel, it has to be passive - the only connections appear to be the two 3.5mm connections exposed on the […]
Can you:
1- Of course I can do
2- Same as above
3- JP1 goes to a front panel "volume dial" thing, JP2 goes to the VU meter itself and two LEDs that illuminates it.
Thnaks a lot for the expert answer, 😀 I'll return back with the requested info tonight.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 3 of 7, by PC Hoarder Patrol
Hope some of these help
installation guide - https://web.archive.org/web/20061207124031/ht … anual/final.pdf
datasheet - https://web.archive.org/web/20070415102631/ht … /cavalier24.pdf
VU-Meter Howto - https://web.archive.org/web/20050819154021/ht … CAVT02_1206.pdf
FAQ - https://web.archive.org/web/20070407205718if_ … duct_ID=CAV-T02
Reply 4 of 7, by tayyare
Can you:
Here are the photos:
251.62 KiB
219.2 KiB
221.21 KiB
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 5 of 7, by tayyare
PC Hoarder Patrol wrote:
Hope some of these help […]
Thnaks a lot for the documentation! 😀
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 6 of 7, by mdog69
OK the quick version:
Get a length of twin screened cable - cable that has two cores surrounded by an overall screen.
At the VU meter board end, wire it to a 0.1 molex connector.
Pin 1: Core #1
Pin 2: Screen
Pin 3: Core #2
The other end gets soldered to the speaker outputs on the back of your sound card.
Screen goes to 0v, the two other cores go to left and right.
Note that it doesn't matter which cable goes to left or to right - the two signals get added together on the VU meter board anyway.
From the documentation provided earlier in the post, the "volume control" is actually a sensitivity control for the VU meter.
If the needle hits maximum all the time, turn the sensitivity down.
If the needle doesn't move enough, turn the control up.
Once you've got it set right, you shouldn't need to change it.
The long bit:
I couldn't read the IC part number, so I put a bet on it being an LM324 quad op-amp.
For the record, the circuit does the following:
The signal comes in on pins 1 and 3, and each channel is AC coupled to the input of a separate inverting amplifier.
The outputs of the two amplifiers are then summed together, passed through the front panel "sensitivity" control and then into a third op-amp which drives the meter.
The whole thing runs off the +5v supply, which also feeds the VU meter LEDs via a resistor.
I think I can reasonably say:
The back panel module is just three sockets paralleled up, two facing outside, one facing inside.
The sensitivity control is probably a simple potentiometer, with the track connected to pins 1&3 and the wiper to pin 2.
The VU meter module probably contains just a meter, and an unknown number of LEDs with no dropper resistor (that's done by R112 on the PCB)
I've got a scruffy hand drawn circuit diagram that I'll scan and attach later for those who are interested.
/md69
Reply 7 of 7, by tayyare
Thnaks a lot for all the detailed information, and of course for your effort, I really appreciated it.
Soldering something on the sound card is a no for me, first of all I really suck at soldering and also I really don't want to fiddle with my only SB32 that way.
Instead, I will do something like this: I ordered the below parts:
78.67 KiB
101.61 KiB
I will solder a fan extension cable to the 3.5mm socket above (because of the 0.1 molex connector at its end), which will be assembled on to a small sheet of metal with a hole drilled on it:
141.15 KiB
123.99 KiB
Then I use the splitter above externally: OneI jack will go into the sound card speaker out, the other jack will go into the the newly created "input port", and socket end will be mating with my speaker jack.
Very much the same way actually that the document above describes. Is there any problems that you can see with it? (apart from the use of an unshielded cable)
Againi, thanks a lot for all the help! 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
