First post, by bergqvistjl
Does anyone know where I can get my hands on an IO shield for a Baby AT board (that specifically has a DIN keyboard connector at the very least). One that would fit an ATX case?
Reply 3 of 13, by Matth79
If you want metal for screening, then you can get blank ones (on a slow boat from China) - and if it only needs one hole for DIN KB, that's about the best case for dealing with a blank - though it would either be a very large drill bit, or a small hole cutter
Reply 4 of 13, by kaputnik
If going that route, I'd use a screw hole punch. It'll be next to impossible to work that thin spring steel like sheet metal with any larger spiral drill than a few millimeters. Maybe a step drill could work if you clamp the shield to a piece of wood, and you're extremely careful, but wouldn't bet on it.
Also, using a screw hole punch is way less risky. Wouldn't want to have my hands anywhere close to that shield if the drill bit/hole saw seizes.
Reply 5 of 13, by root42
I used a step drill and a wood block for my shield. Works quite well. Go slow and cautiously. Maybe apply some cutting oil.
YouTube and Bonus
Reply 6 of 13, by bergqvistjl
Surprised there weren't more of these officially made, given Baby AT boards lasted until 1999...
Reply 7 of 13, by appiah4
Nearly all early ATX cases came with these, they were all just immediately trashed.
Reply 8 of 13, by RetroLizard
I'm wondering if I can buy a pre-made IO shield with just the cutout for a DIN-type keyboard connector from somebody. Any suggestions for that? (I don't have any tools for making my own.)
Reply 9 of 13, by Horun
RetroLizard wrote on 2020-06-30, 22:20:
Most of the real old AT cases did not have a I/O shield, the AT hole was made into the case. I have a few press in type but cannot really spare them as they rare as certain case floppy or HD rails. If you could use a screw in type can gladly send you one free (if you live in USA), it is similar to the one in the picture but AT with DIN KB only or KB and a punch out for ps/2 mouse port..
https://s.yimg.com/aah/mypccase/atx-i-o-shiel … ew-mount-14.gif
appiah4 wrote on 2019-03-15, 06:09:
Only those that were made during the mid 90's AT - ATX transition included them, some were screw in type and not press in like modern ATX (have a bunch for early Enlight cases that AT were screw in AND a few of those cases which would also accept ATX press in)
Reply 10 of 13, by RetroLizard
Horun wrote on 2020-06-30, 23:30:
I'm not sure if the case I'm seeking an IO shield for supports screw-in IO shields.
Reply 11 of 13, by RunningInThe90's
Most of the real old AT cases did not have a I/O shield, the AT hole was made into the case. I have a few press in type but cann […]
Hey Horun, could I bother you to send me one of those screw in i/o shields like in the link? I'm building a piii sys with old parts laying around and it just so happens the case I'm using is uses that type. I would really appreciate it.
Reply 12 of 13, by KVM Nerd
bergqvistjl wrote on 2019-03-13, 11:18:
You can order http://www.vt-shop.online/index.php?route=pro … t&product_id=63. Their shop is also on eBay, but the web shop is cheaper.
Why not hook it up to a KVM switch?
Reply 13 of 13, by p24t
KVM Nerd wrote on 2022-02-09, 10:46:
Link doesn't work.
