First post, by redruM
I used to be able to play GK3 and realMYST in my XP. Now I can't. GK3 gives me some message about problems with resources - the Sierra site said the problem was with the CDs. But it's obviously not the case, as I can copy the files from the CD to the harddrive perfectly - meaning, the drive IS reading the CD.
realMYST, now, I had to put it in compatibility mode. Now THAT doesn't work anymore. A black screen loads, and then the program quits. Nothing else.
Also, Quest for Glory V should have worked, with the patch I got for XP... but doesn't.
I suspect something's gone wrong, but I've no idea what. Can anyone else?
System specs -
Windows XP Home edition SP1 (although sometimes it says SP2, so I don't know anymore)
Intel
Celeron(R) CPU 2.40GHz
2.39 GHz
256 MB of RAM
These were taken from my "System Properties" tab, and I've no idea what they mean. Also, I've got two CD drives, one of which records. Should I add anything else? Can anyone help me? Heck, is this even the right forum for posting this?
"I think you're the fucking antichrist."
--Donnie Darko
