First post, by Taintspore
Hi,
I downloaded DW1 from HOTU, and unpacked it on my winxp machine (tried this in dosbox on my mac but it took too long and the unpacker didn't do everything right (couldn't get sound, got sound but it crashed)) then burned the unpacked game to a cd and moved it to my mac. It runs fine (nothing wrong with sound or graphics) but it won't let me save anything. I also can't change the sound settings with setsound.
So basically it won't let me change the sound settings and I can't save. i think it might have something to do with what directory the game is expecting, if anyone knows the directory DW expects to save in (I have the saves folder) that dw expects to be in and to write to (if this is even the problem) it would be great.
Thanks
EDIT: I'm running a 17" powerbook with a 128 meg 9700, 1gig ram, 1.5 GHz, don't know if this helps, the powerbooks are pretty standard so if there's something missing that you need visit apple.com and a full system breakdown should be there. I also don't think this is a direct problem with dosbox, I think it's just that dw is looking in the 'wrong place' to save the files.
Hi. I editted your post to remove direct link to HOTU site. (eL_PuSHeR)
Reply 1 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Did you install the game on harddisk? If you just burned an existing installation on CD and try to run it from there, then it is normall, that it cannot write anything there... 😀 CD is not writable.
Mirek
Reply 2 of 7, by Taintspore
I put it on my hd, and mounted the folder that the DW folder was in as my c drive. So when I'm in the dw folder the prompt says C:\disc\>
Reply 3 of 7, by `Moe`
Dunno what's on underdogs, but my original (a "game classics" re-release) discworld CD creates c:\discwld.cd, where it copies all drivers (*.mid), the setsound.exe program and a few other files that seem to belong to sound setup. Also, it creates a subdir "saves" where the savegames reside. Other than that, it seems to run directly from CD, and the path c:\discwld.cd seems to be hardcoded.
The following files are found there:
directory SAVE\
DWCONF (looks like generated on-the-fly)
several batch files (*.BAT)
several files called SAMPLE.*, *.DIG, *.INI, *.MDI
RM.DRV
AILDRVR.LST
DWB.EXE
SETSOUND.EXE
Try copying them there, running setsound, then playing the game.
Reply 4 of 7, by priestlyboy
The one from the underdogs is suppose to be able to run from the harddrive but it also contains the files to convert itself back to the CD version which you can burn onto a cd and run from there. I don't recall trying to run it from the HD but I did burn it to a CD and it runs just fine from there. It creates the above directory that Moe referred to as well. And so on.
Side-Note: Mentioned this to QBix earlier on IRC but Flashback still has some difficulties. I actually played through it some. *playing from the CD the SFX will not stay enabled for no apparent reason* And to top it off it sends me a can not write to GlobalBlahblah.ovl error like the first time when it wouldn't even boot up. Except it doesn't happen until after you get to the next section of the game. (Cheat Code: REPLAY) Then play up until the FMV video and watch that and it "crashes" with the above error right after it.
Ieremiou
Helping Debug DOSBox.
Reply 5 of 7, by Virtul
i have trouble with saving too:
game works ok without dosbox, but when i try to save a game in box, game creates another one SAVE folder in already existing one and puts a save there (\SAVE\SAVE\SG.1)
after when i go to another screen it crashes saying couldn't find files DRIVERS\ISOUND.BAT and UNSEEN.GRA (that one is in main folder)
so it changes working folder during saving but doesn't changes it back
using WinXP SP2 with 0.63 DosBox
(tried mount on c:, d: and d:\discwrld seems my trouble have nothing to do with mounting...)
Reply 6 of 7, by jamaicaplain2002
Ha ha I found an answer that works for me on a random download site comment: Had to rename the program directory to c:\discwld (note no 'r'). Before saves did not work, afterwards they did. I'm running using boxer on a mac.
Reply 7 of 7, by Jorpho
Good $deity, you just bumped a nine year old thread!
You can run Discworld with ScummVM now and I don't really see why you would use DOSBox instead.
