First post, by Roman78
I own a HP Thin client T5730: https://www.parkytowers.me.uk/thin/hp/t5730/
I want to install Windows 98 on it for some retro gaming, this has a ATI Radeon X1250 GPU, but i am unable to find the appropriate driver.
Also need the USB, Audio, Netwotk and SMB driver. There is an ATI Chipset on this one. I think most of that are in the ATI-Chipset integrated.
/Edit Audio is ALC262.
Reply 1 of 3, by Garrett W
If you could find the chipset for this, then perhaps you could be able to locate the drivers. Unfortunately, as far as I know, the last ATi GPU series to be supported under Win9x was the R400 based cards such as X700/X800 and so on. Starting from X1xxx they moved away from Win9x, so unless there is a modded driver somewhere or some way to force older drivers to pick the card up, you're out of luck. There is a chance the latter will work, as X1250 is probably based off of something older than the rest of the X1xxx line of cards.
